- Sep 7, 2006
- 2,972
I agree about these tanks, I was not impressed at all for the amount they cost. One of my biggest complaints is that the pump is mounted to the bottom of the tank, it should be mounted like the OEM setup, so when you remove the top access plate the whole assembly comes out, pump and sending unit, its a real PIA to install a new pump in these things, also it would cut down on noise when the pump is running. Also the pickup and return lines being next to each other makes it so that its almost impossible to use both the supplied AN 90* fittings and make it look nice.
As for the sending unit I bent the arm down as low as possible so it reads full a long time but once it is on "E" there is only ~2.5 gallons in the tank.
These tank designs and sending units need some serious work especially if you are gonna charge that kinda $.
I'm not trying to bash WH, I do like doing business with them, their customer support has always been good to me, however I do think we need to let them know about these things so they can work on getting the problem fixed and build a better product.
