66Gasgrill
Throwing this out there as i need to make some room and money. I have decided to sell the gas grill. Asking $9,000.....
1966 ford Bronco rock krawler (project)
5.5" lift 37" krawlers
Motor:
200 straight 6cyl on propane, 3G alt. W/master fuse, Aluminum radiator w/elec. fan, pertronix electronic ignition, Saginaw ps pump, f150 4x4 ps box
I also have a turbo to go with it but it is not installed
Drivetrain:
Np435 granny 4spd. Twin stick Dana 20
Suspension:
5.5" lift wild horses springs, 11 pack leafs,
14" Bilstien 7100's up front on Duff hoops
12" Bilstien 5125's on in board mount w/ anti wrap bar in rear, extended and heimed radius arms
Front Axle:
Full width HP D44, Yukon axles with Yukon super joints, BC Broncos wristed axle assembly, 4.88 gears on Detroit locker, Dynatrac diff cover, 1.25" .330 wall dom steering links with 3/4" heims, disk brakes, lockout hubs
Rear Axle:
Shaved full width big bearing 9", 31 spline axles, 4.88 gears on full spool, anti wrap bar with inboard shock mount, disc brakes
Roll cage, corbuea baja ss seats, taffy console, cobra cb, auto meter phantom gauges, gorilla warflares, custom bumpers winch mount on the front 37" blue label BFG Krawlers on 17x9 wheel with sky beadlocks
Body:
Now for the bad. The body is in prices I tore it up wheeling and started on a redo and never finished. As it sits the grill has been narrowed 8" and the hood sectioned to fit however the rear is completely off the truck. I have the original quarters where I cut them off as well as another set from a different truck I have most everything to go back a couple different ways.
It was a great wheeler and a decent looking truck at one time but I have to many irons in the fire (literally) to just let it keep sitting. She needs a new home. I can take pics of any thing you want to see. Thanks
Motor:
Drivetrain:
Suspension:
Front Axle:
Rear Axle:
Body:
