- Nov 29, 2010
- 606
I just installed both rear wheel cylinders since the old ones were leaking badly. After two drives the new ones are leaking just as bad as the olds ones. It's a 67 small bearing axle. I did install front disc brakes recently and new 1974 f250 MC. So, is the MC pressure blowing up the wheel cylinders? I find it hard to believe both the new ones are bad since they bled find and held pressure for a bit. Thanks in advance!
