Did a few searches but did not find my answers. Frame off resto. I'm getting ready to put the body back on the frames, for paint. Have upgraded to power brakes, power steering and adding a Fitech. Considering a 1" body lift for aesthetics, but also for the possibility of using a HEI distributor. What other mods will I need if I go with a 1" body lift?
Will
Depending on suspension lift with the body lift... you might need to:
Have longer brake hoses front and back
Longer emergency/parking cables
D20 shifter may have to have modifications, as it with be lower
The 3 holes in steering column support bracket may have to have to be slotted to adjust it down.
May have to change steering shaft if it is the solid piece one, to prevent binding
May have to lower the shroud for fan clearance.
Maybe extend wires, if stock harness.
Just off the top of my head...
