I can get aluminum 165 heads(almost new) for my 302 (at the machine shop now), for $800. New cast iron, same heads, 800 plus rocker arms, etc. Assuming good heads, do I go with cast or aluminum? The question for me is am I going to have any problems with the aluminum heads (stripping bolt holes out, etc.). Is there any significant advantage to the Al. heads with the same specs as the cast iron other than the weight advantage? Thanks
