Thread Tools
Old 05/27/18, 04:27 PM   #16
AZ73
AZ73's Avatar
Barn Find
Scottsdale, Aridzona
I used Noico deadening. It's like Dynamat extreme, but 15% thicker and a LOT less expensive. It's the same Butyl as Dynamat (other knock-offs use tar or asphalt) but some people claim the aluminum isn't as thick. I don't have a problem with that since it will have heat insulation above it and how much difference is a couple of microns of aluminum? I laid it out in the sun before I installed it and it went in no problems. Pics when I get back home.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I'm topping it off with their heat insulation which is like Dynaliner - closed cell PE foam. Again, a lot less expensive, although when I went to copy the link, Amazon is out of it at the moment.
https://www.amazon.com/dp/B074V7Z262...=3200120240901
The savings paid for my Tom's carpet kit.
Barn Find 73 going through a nut and bolt Restoration/Upgrade. Follow along at:
http://classicbroncos.com/forums/sho...d.php?t=217635
"If you don't stand for something, you'll fall for anything"
AZ73 is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.28671 seconds with 62 queries
