rydog1130
- Joined
- Jun 19, 2014
- Messages
- 4,019
Ok guys I’m running a centech harness and I’m having huge issues as in NO PoWER issue. My brown heater wire has no juice, I checked fuses on everything and they are all good! I ran a direct ground to all my grounds and still no power? Is my fuse block bad?? I ran a direct lead to my heater switch and it works appropriately so I know it’s not my motor or switch. Also my power source for my washer fluid is not working. Once again everything grounded and sand thing, tester light does not indicate power at the end of the purple lead. One other issue is there are 2 orange wires connected together indicating accessory power. When the key is turned to the accessory position I have no power there as well. Do u think it’s a faulty ignition switch? The car still fires up and starts so I’m stumped. I even upgraded the ignition switch and not using the one centech included in the kit. Lastly my cigar lighter was shorting out, I think it’s got an internal short because it was still blowing a fuse without the lighter in it. I unplugged the gray wire and it stopped blowing the fuse and I tested the gray wire and it has power and doesn’t blow the fuse while being tested. Now my dome lamp is on the same fuse but lumped in with some other wires and it does not have power. There are some ground wires associated with the bundle it’s gtouped with so I will try those tomorrow!! Any other help would be greatly appreciated!
Thanks!!!
Thanks!!!
