yes you can reuse your column, i'd cut it down and put a slip shaft in it for safety.
you can piece together your own from any of the manufactures like flaming river, borgeson or just order one up from one of the vendors.
you will just cut your shaft down a few inches below the column body and grind it into a 3/4" double D shaft to accomadate the upper joint and the rest is bolt on.
