73EB
Available.
https://fayar.craigslist.org/cto/d/69-ford-bronco/6331823704.html
1969 FORD BRONCO 4X4 302, T-19 4 SPEED, NEW PAINT. IT HAS A FIBERGLASS HOOD, 6 POINT ROLL CAGE TIED INTO THE FRAME, CUSTOM BUMPERS WITH D RING HOLDERS AT EACH CORNER & WINCH PLATFORM UP FRONT, INSIDE IS RHINO LINED WITH CUSTOM BUCKET SEATS, TUFFY CONSOLE. 4 MARINE SPEAKERS AT EACH CORNER WITH AN 3.5MM JACK TO PLUG IN PHONE TO PLAY MUSIC. NEW ALL ALUMINUM RADIATOR, NEW STARTER, FUEL PUMP AND BATTERY. HAS HARD TOP AND AND BIKINI TOP. ROCKERS HAVE BEEN REMOVED AND ROCK SKI'S HAVE BEEN INSTALLED.
THE 302 IS A 68' BLOCK HIGH ZINC, LUNATI CAM, PORTED HEADS, EDLEBROCK PERFORMER INTAKE WITH QUADRAJET 4 BBL CARB, HEADERS AND FLOMASTER ON 2 1/2" EXHAUST. T-19 BORG WARNER 4 SPEED WITH NEW LUK CLUTCH AND PRESSURE PLATE AND FLYWHEEL.
THE FRONT AXLE IS A DANA 44 WITH CHROMOLY AXLE SHAFTS AND DETROIT AUTO-LOCKER, 4:56 GEARS. CROSSOVER STEERING WITH PCS HYDROLIC ASSIST STEERING AND WARN HUBS. THE REAR AXLE IS A BIG BEARING 9" 31 SPLINE SHAFTS, 4:56 GEARS, SPOOL AND DRIVERS SIDE IS A YUKON SHAFT. DRUM BRAKES AT ALL 4 CORNERS. 500 MILES ON NEW MICKEY THOMPSON MTZ P3 MUD TERRAIN TIRES 35X12.50R15. ALUMINUM 15X10 WHEELS.
SUSPENSION CONSISTS OF A 4 1/2" WILD HORSES COILS, AND REAR SPRING 11 COUNT PACK. FRONT HAS JAMES DUFF EXTENDED RADIUS ARMS. F-250 SHOCK MOUNTS, 2" BODY LIFT WITH NEW BODY MOUNT BUSHINGS. NEW C BUSHINGS ON THE RADIUS ARMS AS WELL. VEHICLE IS LOCATED IN CENTERTON AR.
Jeff (479)381-4092
Jeff (479)381-4092
