Intro and build thread from Canada
W
wizard12
Time for a body
Thanks Pipeline. FYI - I painted everything using POR and a paint brush. No spraying was done to any parts. I was really pleased on how it smoothed out once you finished putting it on. I was much the same way and ended up shoving the paint brush into every nook and cranny on the frame/axles.
Here is the fibreglass body from BD. I got it shipped up to Minneapolis and made the drive down to get it (18 hours one way). It was mid December 2016 and some of the coldest weather I have every been in (-36 Celcius). The trip eased any fears I had of a fibreglass body. It did very well in the extreme temperature, no issues at all.
W
wizard12
Transfer case
The original transfer case was toast as it was left out in the elements and would require a complete rebuild.
Since I planned on going with a 5 speed from 1993 F150 I decided to use the money spent on an adapter to buy an NP205 and did a quick rebuild on it. Great videos on YouTube for anyone thinking of doing it.
Disassembled
Empty case
Wire wheel cleaned it up nice
Painted and reassembled
I ended up ordering the JB Fab twin stick and did the grinding on the shift rails.
I really liked how the silver/black looked when finished.
Warning - That is one heavy girl. Had to make sure it was on the edge of my table as it was starting to flex it in the middle.
Crush
Greenbottom, WV
Make sure you build a mount from the tcase to the frame using those three holes on the front output side of the case. a simple L bracket from there to the frame with a body bushing or trans mount bushing (round) like the stock bronco ones between the Lbracket and the frame to allow for twist and vibration will work fine. that mazda trans will crack at the tailshaft supporting all that 205 beefieness. there are several threads on here where this has been done
hope this helps
W
wizard12
Hey Greenbug, I bought a 1993 F150 with the 5-speed. I realize it is not the zf, but I have had a similar truck with the M5 transmission back in the day and really liked it. The Bronco will be a pavement princess 100% so not worried about a sure lower first gear for off road.
The plan is to use the existing powertrain (engine and transmission). I know the intake will not fit so I have also picked up a used upper and lower mustang intake.
When I took the truck intake off, I discovered the engine is a roller, but with the non HO firing order. Now I just need to find a throttle body and figure out how I am going to do the wiring for the EFI as it is past my comfort level of doing electrical work.
Hope to get some more progress pictures up over the weekend.
W
wizard12
Thanks Crush. I ended up buying/using a TMR support kit.
https://www.tmrcustoms.com/ca/transfer-case-support-kit-np205
I put this off the back output with square tubing running between the 2 frame rails to reduce the hanging weight. I will try and get some pictures of the finished product. Let me know if you think it is sufficient or should I also do something on the drivers side support. Always looking for opinions of others who have a similar setup.
hope this helps
pipeline010
ya that body looks pretty sharp.
I may be finally warming towards FG for the northeast over steel.
Crush
Greenbottom, WV
WIZARD = Didnt evenknow that existed. looks like it should work fine. I dont havve that setup but have often contemplated it and in my research found the way i suggested to be the norm but that kit from TMR looks really nice
nick1975bronco
Where are you located in Canada there are a few of us bronco guys out here. I would like to check out one of those glass bodies been thinking about them a long time so I can build a rust free bronco.
W
wizard12
Hey Nick, I am just outside Airdrie so not too far from you. If you ever come up this way you are more than welcome to come by and check out the fiberglass body. I detest rust so I am definitely a fan.
W
wizard12
Fitting parts on
Time to start putting parts on the body.
Put in seats and tacked up the roll bar to make sure it would fit.
Doors and topper on to see how it all lines up.
Engine from donor truck on frame. My initial plan was to swap intake to mustang.
M5 transmission from donor truck. Needed new slave cylinder so had to separate from engine.
Next pictures will be after paint and starting final assembly to where I am currently at. Hope to get them up in next day or 2.
bronkenn
Bronco Guy
Southeast Ohio
Just an FYI. You can find a top shifter trans cover off of a newer M5 that will move the shifter back considerably. I got one off a 2002 f150 and it took very little modifying to fit. Ken
nick1975bronco
I definitely come take a look I live down in Nanton and work in calgary. Looks great seems to line up nice. I too am a hater of rust lol. Also the m5 out of a thunderbird SC has the shifter towards the rear.
W
wizard12
Thanks Bronkenn. I just looked up your thread on how you show the difference on the shift forks and all that is needed is a bit of grinding. Will definitely look into this. I didn't realize there were any manual transmissions in the trucks past 96-97. I am guessing there is a reason you didn't go with the entire transmission from a 2002?
Also noticed the nice hydraulic line you have on your transmission. Did you order that from somewhere? All I have is the plastic hard line from the donor vehicle which needs replacing anyways, and would rather go with something flexible as I am sure the distance will now be different than what was stock.
W
wizard12
I will send you a PM with my phone number. Give me a shout when you want to come by. Kids keep me pretty busy but sure I can find some time to connect.
I did the commute for 20 years to downtown Calgary. In January I decided to take a break and get caught up on life/kids. Once the Bronco is done I might have to relinquish my Mrs. Doubtfire duties.
bronkenn
Bronco Guy
Southeast Ohio
The reason I went this way is I already had the trans out of a 90 f-250 and knew it was a strong trans. I am not sure of the differences in the older M5 in the heavier duty truck compared to the newer f-150. The newer ones had the 4.2 V6 motor so I wasn't sure if they are as strong. The shift cover can come from a two wheel drive as well.That braided line was an3 and I found a way to adapt it to the throw out bearing and clutch master. If you want details, I'll have to dig in it a bit to see what exactly was used. Ken
