Those gaps
rjcruz27
I know this gets asked 1000 times. But is it a big deal if one side of your bronco doors gaps are a little different. One side is 1/8 pretty all the way around. The other side is just under 1/4 all the way around. Thanks guys/gals
Skiddy
not that big of a deal to me, you will probably be the only that will know it. you can only see one side at a time;)
phred
Earth
Ford built these things to be work trucks. Gaps were never a consideration. If the doors shut and sealed then it was “job one” and out the door.
Rustytruck
1/8" is pretty tight for a stocker. 3/16" -1/4" more the norm and the bottom was larger than the side gaps.
edmedlin
Republic Missouri
I am old enough to have seen and ridden in EBs when they were new. They rattled.. They whistled.... The rear hatch seemed to show light through them in places. The early Broncos were never meant to do anything much other than work and get you to places a normal car couldn't. Body gaps??? hehe. Ever looked at almost any vehicle from the 60s and 70s? MOPAR was probably the worst. If the doors open and close and seal fairly well without loud wind noise, you are pretty close to what they were new.
sprdv1
REBEL
for sure that's a fact....
Rustytruck
You need to keep the door gaps on the wide side of specs if you want a chance of new door seals to work, especially at the bottom of the door.
