Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 04/16/18, 12:52 PM   #46
904Bronco
904Bronco's Avatar
So many Ford's, so little time...
Morgan Hill, CA
Originally Posted by bsquared View Post
Hey Doug,
Where did you pick up those cool molded heater lines? I have one for the return that will work, but I'd like to source the two that the valve is in.
Thanks and got the PCM window cut this weekend and test fit the engine!
Cheers, Bill
I am going to have to dig up those numbers, I took a few hoses home and made them work by cutting sections out of them. I believe most of them were Gates... And I have found that other manufacture's are not exactly the same...
1967 Poppy Red U15 Lubr... soon to be 96 Explorer EDIS and NV3550
1971 Grabber Green U15 Lubr... 2000 Explorer EDIS and 4R70W
2016 Shelby GT350 - Race red
2002 F250 Superduty 7.3 202K and still going!
1996 Saleen Mustang 125K... Project car
904Bronco is offline   Reply With Quote
Old 04/16/18, 01:00 PM   #47
bsquared
bsquared's Avatar
Houston
Thanks Doug,
Don't spend too much time searching. I'll print the photo you posted and can probably find something from there. Appreciate the help! B2
1970 uncut, 96 Exploder 5.0L, ZF, NP205, EFI, 2" BL, 2.5 SL, Dana 44 w/ 76 Bronco discs
bsquared is offline   Reply With Quote
Old 04/16/18, 05:29 PM   #48
904Bronco
904Bronco's Avatar
Morgan Hill, CA
Thanks Doug,
Gates #19070
Price range from $15 to $22 Rock auto was the cheapest... You cut out what you need and make it fit... I think it was the only one?
https://www.oreillyauto.com/detail/b.../19070/4326309
Old 05/17/18, 11:19 AM   #49
bsquared
bsquared's Avatar
Houston
Making headway, slowly but surely. Wiring harnesses are complete and I just need to run my wires into the cab and hook them up. I think my original harness, dubbed "Old Crusty", came out pretty good. Once I have it hooked up in the cab, it'll time to pull the engine, hook up the tranny and re-install. Fingers crossed that it'll start!
I'll be needing to add 3 switch panel to operate the high idle function, fog lights and on board air. Don't want to cut the dash, so does anyone have suggestions for an add on panel?
Thanks, B2
Click image for larger version
ID:	452186   Click image for larger version
ID:	452187   Click image for larger version
ID:	452188   Click image for larger version
Old 05/17/18, 12:13 PM   #50
Local Boy
Local Boy's Avatar
More throttle...Less talk
Mililani, Hawaii
Cool Looking good!
Thanks, B2
I would suggest glove box * If you still have one
or
Center counsel * If you got one...
Aloha
XCON BR #1 - 408 Stroked Dart block, Forged rotating assembly, Jon Kasse P-38 heads, Jesel valve train, Atlas II, Hughes Built C-4 w/ manual valve body, RCV 31 spline front axles, F-9 Currie 9' 35 spline rear end, BigStuff3 Pro SEFI
"Every time I turn on my Bronco, it returns the favor!"...
Local Boy is offline   Reply With Quote
Old 05/18/18, 07:54 AM   #51
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Nice work chief....
Thanks, B2
sprdv1 is offline   Reply With Quote
Old 05/18/18, 09:42 AM   #52
bsquared
bsquared's Avatar
Houston
or Center counsel * If you got one...
Aloha
OOoooo......Good call, Local Boy! I'm thinking the Tuffy Console would be a pretty slick location for those switches. Thanks for the tip....I gotta take some measurements! Feeling bad for the peeps on the Big Island. Hope all turns out okay.
Cheers, B2
Old 05/18/18, 09:43 AM   #53
bsquared
bsquared's Avatar
Houston
Originally Posted by sprdv1 View Post
Nice work chief....
Thanks Super Dave! Ready to be done, but trying to go slow so I don't screw anything up!
Have a good weekend, Bro!
Old 06/24/18, 09:54 AM   #54
bsquared
bsquared's Avatar
Houston
Have made HUGE progress in the past couple of weeks and she's up and running! Took me a while to figure out that my coil pack terminals were not fully seating in the connector, but once I got past that she fired right up. Then, in a Ju-Jitsu tease move and after getting EVERYTHING buttoned up, my clutch slave cylinder decided to go belly up from just sitting on a shelf for 6 months. (WTF?!)
I found a 3 gang rocker panel plate that fit perfectly in the ash tray opening. (No cutting of the dash, WooHoo!) Did the ViperWolf mod to the throttle cable setup and looks like it is going to work well. (thanks, Viper!) Need to find a stronger return spring, but I think that's about it. (other than putting everything back together, AGAIN!)
My first time trying to post a video, but we'll see if it takes. Don't have much else to report, other than it's been an expensive journey! haha Cheers, B2
https://www.facebook.com/bill.bell.5...58711024/?t=33
ID:	454918   Click image for larger version
ID:	454919   Click image for larger version
ID:	454920   Click image for larger version
ID:	454922   Click image for larger version
ID:	454923   Click image for larger version
ID:	454924   Click image for larger version
ID:	454926   Click image for larger version
Old 06/24/18, 08:30 PM   #55
bsquared
bsquared's Avatar
Houston
Couldn't do much until the slave gets here, but managed to get the brake line to the rear axle finished with no leaks and since all this crap started with an engine fire, got a couple of extinguishers mounted. (not sure how I'm going to keep them theft proof)
Cheers, B2
Old 06/25/18, 09:45 AM   #56
trailpsycho
trailpsycho's Avatar
Indianapolis
Where did you score the rocker switch/12V assembly that fit into the ash tray? Me likey!
Truck looks great!
Frame-up...Explorer 5.0 EFI, NV4500 and D20 (TLG and HD OS), Yukon alloys (w/ SJ) F & R (31 spl), ARBs and 4.88s. F250 h-boost w/Lincoln MC and 4W discs riding on 5.5" Deavers, Cage arms, hoops and shocks. Full Line-X inside, underneath and upside down, custom cage, 35" MTZ on black Eagle alloys.
trailpsycho is offline   Reply With Quote
Old 08/08/18, 09:49 AM   #57
bsquared
bsquared's Avatar
Houston
Been a while since I've posted, but wanted to give an update. She was up and running, but something wasn't right. Had a wicked belt squeal that I could not hunt down. Changed out all of the idler pulleys and it was still squealing. Then, after a test drive it just died in the garage and I knew I had to look into why.
Well, I call him "Mr. Nutley"! Did a compression test and #1 came in with a whopping 0.0. Pulled the passenger head and found Mr. Nutley imbedded in the piston. Luckily it wasn't any worse. Pulled it all back out and replaced the piston, connecting rod and intake valve. Got the block back in last night and putting it all back together this evening. Will update with more info once I get to turn the key....again!
TrailPsycho, I got that rocker panel off of e:bay from a supplier called carmotors2013:
Marine Switch Panel, 3 Gang Rocker Switch Panel...
Item ID: 222613848240
Quantity: 1
Estimated delivery: Wed. May. 30 - Tue. Jun. 19
Paid: $27.24 with PayPal
Seller: carmotors2013.
It came from China, so it took about 2 weeks to get here, but it fit perfect so it was worth it! Cheers, B2
ID:	457790   Click image for larger version
ID:	457791   Click image for larger version
ID:	457792   Click image for larger version
ID:	457794   Click image for larger version
ID:	457795   Click image for larger version
ID:	457796   Click image for larger version
Old 08/08/18, 02:47 PM   #58
bronkenn
I believe you, thousands wouldn't
Southeast Ohio
I hate Mr Nutley
bronkenn is offline   Reply With Quote
Old 08/08/18, 03:33 PM   #59
Rustytruck's Avatar
honest the bolder ran under me
El Monte CA
Looks like time to replace the rear main seal and freeze plugs while its out. MR. Nutley looked to be too big to get past the valve. Was it a spark plug insert? looks like a rivnut.
Oh well now you really know the condition of your motor. Good to go for another 10 years. Truck sure looks sharp you did good in your fire recovery.
1974, stock 302, C4, BFG KM2 33x12.5x15, 8in rim, detroit rear, trutrac front 4.11 gearing, Warflairs,2.5" lift, chevy disc conversion, Hydraboost, owned since Christmas Eve 1977
Rustytruck is offline   Reply With Quote
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.42281 seconds with 63 queries
