tatersalad
- Jan 17, 2009
- 1,067
I have a 351w tied to a c4 trans, bcb adapter with rjm and a9s.... everything has been running fine with the setup for about 8 months but now I am getting an intermittent check engine light while driving... it kind of surges while the light is on... I ran a koeo test and got all the soft codes that rjm says is normal but I did get an additional cm code 63 (TP voltage to low) Is there a way to test the TPS first, before buying a new one... all my sensors were used when I converted over to EFI and I assume that I will be replacing them eventually I just don't want to throw parts at it... Thanx
