I had Rancho 9000's on mine then switched to 6100 series Bilsteins in front. No adjustment of the 9000's could make them ride as well as the Bilsteins, on or off road. You have to experience them back to back with the Ranchos to believe it. Because of the speed sensitive valving, no external adjustment is necessary. I still haven't replaced the rears, but they are getting swapped with the next paycheck, for a pair of 10" travel 5100's.<br><br>The 5100 series Bilsteins are available in travel lengths from 6-1/2" to 14", though for the same travel the longer models tend to be longer than comparable travel Ranchos. As far as I know Bilstein doesn't make stud-mount shocks like the stock EB uses up front, but you can get F250 mounts from BC Broncos for $32 a pair to fix that. That also lets you use a longer shock up front, so the shock no longer limits wheel travel.
