G
Guest
Guest
Can you mount the master cylinder on the firewall using washers on the inner mounting bolt to shim and angle it away from the engine? Has anyone tried this? According to my calculations, 2 .032 washers will angle it approx 2deg, giving me around .200 clearance. Will I have problems with the rod or anything? My EFI 5.0 HO plenum will interfere with the disc brake master cylinder. This only needs to hold up for a few weeks, I'm already collecting stuff to do the Hydroboost converison (like Todd Z.'s). I would like to do the front disk swap this weekend, I think the hydroboost & disk conversion would be more than I could tackle in a weekend, and need to get to work every Monday .
