CounterReset
- Dec 11, 2018
- 1
New Holley 2300 Sniper EFI Master Kit
Brand New. Bought two and was going to use this one for my RV but decided to go a different route. MSRP is $1288. Save $288. This is a complete kit. Price is firm.
Jon
808.294.5000
From Holley:
Features:
Bolt on 2300 Flange Carburetor Replacement
Supports up to 350HP with Two 100lb/hr Injectors
Equipped with C4 / C6 Ford transmission kickdown lever as well as TH350, 400 and 700R4 provisions
Accepts many common 5 1/8" OEM or aftermarket air cleaner assemblies
Throttle body mounted ECU - no extra boxes to mount
Integrated ignition timing control
Only 4 Wiring Connections Required! (Battery +, Battery - , Switched Ignition & RPM)
Internal fuel pressure regulator eliminates the hassle of plumbing an external fuel pressure regulator (Preset to 58.5 PSI)
High Resolution Full Color Touchscreen for Initial Setup, Tuning, and Gauge Displays
Simple Calibration Wizard (answer a few questions about your engine and it creates the base map, then starts tuning on its own!) - NO laptop required!
Self-tuning ECU means you don't have to be a computer/tuning wiz to have EFI!
The included Genuine Bosch LSU 4.9 Wideband Oxygen Sensor provides realtime Fuel Map Learn!
OEM Style TPS/IAC and Fuel Pressure regulator, for years of dependable service.
Included clamp-on oxygen sensor kit for 2.25" exhaust ensures a leak free oxygen sensor installation, with Stainless Steel T-Bolt clamps and a Stainless Steel (Weldable) oxygen sensor flange
Sniper EFI Software free to download which allows for realtime tuning
Printable throttle body flange template included
Jon
808.294.5000
From Holley:
Features:
