- Aug 27, 2001
- 5,144
Ok...worked on her again today and got it wired up and started. Everything seems to be hooked up correctly now. I got rid of the previous owners solid black wire from the starter(ST) to the switch, and instead used the factory red w/blue wire which was still hooked up to the "S" terminal too and followed factory red w/blue stripe wire from the "S" side of the solonoid in through the pass. side of the dash, under the dash, and back out of the drivers side of the firewall to the neutral safety switch that is normally used for automatics, but is still wired in anyway. I spliced into this wire and ran it as my start wire and hooked it to both of the red/ w blue striped wires on the factory pigtail. My only problem is that it doesn't start until you let off the key to the run position. This is exactly how the aftermarket switch performed too. Not sure why its still doing this. Any ideas?
(ACC) Old black/green on factory harness = black/green new factory pigtail
(BAT)Old yellow on factory harness = Yellow on factory pigtail
(IGN)Yellow wire (not sure original color of this wire, it was spliced where it comes thru firewall from coil old harness = Green/red and red/green
(ST) Red/ blue wire from starter = both red/ blue wires on factory pigtail
Lord I hope this makes sense Let me know why this baby starts only when you let off the key
Thanks,
Andy
Blue71
Thanks,
Andy
Blue71
