OCBR 2017-Come & Gone. **What was Your Fav Part of the Week??
Fitz24
And...????
I'm ready whether or not the bronco is or not Going to be Wore OUT
Back from Chicago morning of 9/18, pack, load up, hit the road
You'll still get there before me. I can't head out until early on the 20th. Hope to hit HS bout 4pm.
sprdv1
sprdv1
REBEL
Safe travels to all, it's getting real close, around 4 dang weeks...
NYLES
May have made a difference but to late now. Should have probably waited to add truss to back of the housing to see if the welds stopped the leaking. Doesn't leak much but still aggrevating to see that little spot on the garage floor.
What you really been doing I don't remember any truss????
Skiddy
And...????
yeah we will be coming back from branson the 17th, then load up and head out the 18th;D
garberz
Bronco Influencer
Conejo Valley, Ca.
Ok, checked a few things off my prep list. I have a quick trip planned on the wine trail over Labor Day. Then I have one weekend left to get packed up. I'm heading to Tx. early morning the 16th. Then headed to Hot Springs the 20th.
Mark
sprdv1
sprdv1
REBEL
Get after it brother... If I was near ya I'd help out
Fitz24
Added truss while I had the housing out to welding up the back cover. Should have made sure the welding sealed the leak before adding the truss. Really didn't think it would leak. I left it set for a couple of days after welding the rear cover with water in it and had no leaks. Heated up gear oil and the pressure in the housing makes a difference. I didn't want to remove housing again to fit the truss and weld it. Now I wish I had.
BIGED
Guru ????
if mine doesn't leave some kind of spot on the garage floor I get worried
Boss Hugg
OCBR 2017 - We Ready - ALMOST TIME!!
Almost ready. Got some flare on and a little bling to boot. Now it's time to hammer on details, whatever they are.
Two come to mind. Cb antenna. And my right front hub won't stay locked... it kicks out and I don't understand how that happens. It's an oem ford locker.
sprdv1
sprdv1
REBEL
Soooo close
sprdv1
sprdv1
REBEL
Beat ya. Completed scanned and emailed last week. And electronic check sent
I am running out of time quick
Out of town to LV next wknd. Step child wedding the following wknd. Uugh
Fitz24
I have a business trip to LV 2 weeks after OCBR. Hate going out there. Work in a casino every day. LV is the last place I want to go.
