Did I cook my gears
turbotim2
____________
Installed new gears in my 9". I set them up according to Yukon's instructions, got a great pattern. At the same time I installed new bearings and rebuilt the stock Trac Lok. I have maybe 75 miles on them and they are starting to growl around corners and I can feel what seems to be the teeth meshing together. They are quiet when driving straight. Thanks!
did you loctite the ring gear bolts? Still have backlash between the pinion and the ring gear?
sykanr0ng
/\/\ That +1
There are other differentials like the TrueTrac which do not need the friction modifier and tell you not to add any.
The oil companies only want to make one oil, so they leave it up to you to add it for those differentials that need it.
bronconut73
Lucas gear lube says you don't need to add friction modifier but I always have had to when using it in a limited slip.
cali_zuk
Did you soak the clutch plates in friction modifier before re assembling it? If not, add some friction modifier, (I use dana spicer part number 43161) that should take care of it. I forgot to put friction modifier in a diff one time, and the noise it made sounded like it had been driven 100's of miles with no gear oil. Once I noticed my mistake, I put it in, and almost instantly the noise went away.
ribbits
May be a dumb question but, I have a ford 9" with Detroit lockers.. Should I be using the friction modifier? Not having any noises but what can it hurt to add it? What about the front end Dana 44? Thanks
blubuckaroo
Grease Monkey
Ridgefield WA
The chatter can sound like you've wiped the gears out, but it really doesn't affect the gears at all.
The difference is the OEM limited slip units aren't nearly as tight as the aftermarket units.
The oil with additive already in it is fine for OEM, but even my soft Yukon unit chatters with it unless I add the stinky stuff.
As stated above, your ring and pinion are fine.
It is the limited slip that is giving you fits. You can tell because it only happens in turns, where the limited slip must allow a differential action between left and right sides. In a straight line it doesn't have to slip and only the ring and pinion are the moving gears. With things fine in a straight line, the ring and pinion are fine.
Additive for the fix. If that doesn't do it, there is a problem inside the limited slip.
ribbits
Mine suppose to have Yukon gears?? Just wondering what it would hurt to add it because I really don't know if it has it (additive) in there or not?
blubuckaroo
Grease Monkey
Ridgefield WA
You only need the friction modifier additive if you have limited slip. If you use it without limited slip, it won't hurt anything. Except maybe your wallet.
The brand of gears or brand of limited slip doesn't matter.
ribbits
Much obliged !!
sykanr0ng
NO
You have a Detroit Locker.
Only clutch type limited slip differentials need the friction modifier.
The Detroit Locker is not a clutch type or a limited slip.
ribbits
NO
Kinda what I thought,,,, now I feel like Johnny Ringo ??? Thanks%)
cs_88
I used one whole 3.8 oz bottle of the Ford Racing stuff.
Timmy390
Conway, AR
As I recall I added 4 oz. to mine.
I've since moved to a Eaton True-Trac (parallel-axis planetary helix gears to provide a quiet, automatic splitting of torque. They perform like a limited slip differential under normal driving conditions, automatically transferring torque to the wheel with better traction when ground conditions warrant)
My 2014 Shelby has the Ford version called a Torsen Diff.
No special oil requited and they last a long time. Must be tough to handle the 662hp and 631 lb-ft of torque the Shelby is putting out.
Tim
