Transfer Case Shifter Repair
admin
Administrator
Just your friendly, neighborhood webmaster...
Phoenix, AZ
Tech article by smokeater11
Is your t-case shifter so sloppy that you can hardly get it into gear? Well I found a cheap and easy fix for this problem. Even if the shifter is still in the truck this should take less than an hour and cost less than $10.00.
Here?s what you need:
