Go Back   ClassicBroncos.com Forums > Classifieds > For Sale - 66-77 Broncos by members only
Old 03/19/17, 09:55 PM   #1
bob_lafrentz
bob_lafrentz's Avatar
Cody, WY
Built 1969 Bronco
City: Cody
Price: $25k
1969 Ford Bronco (over $30k in this rig)
  • New ignition switch, lock cylinders, headlight switch, dimmer switch, turn signal switch
  • Radiator cleaned and rebuilt, new radiator hoses, heater hoses, and radiator brackets
  • Door hinges rebuilt
  • New Centech body harness and ignition switch harness
  • New NV4500 (5-speed manual) and Atlas II transfercase from Advance Adapters
  • Centerforce II clutch
  • New high angle drive shafts (front and rear)
  • IDIDIT tilt steering column and Grant steering wheel
  • Flaming River steering column joints
  • New BC Broncos power steering kit
  • Rebuilt D44 front axles with new seals, bearings, Warn hub locks, braided brake lines, F-150 tie rod conversion, new bumpstops, new bushings, new trackbar, heavy duty D44 axles, F-150 heavy duty knuckles/spindles, new ball joints, and new rotors/calipers/pads
  • Rebuilt Ford 9” rear axles. New wheel cylinders/brake shoes/drums, braided steel brake lines, new axle seals/bearings and pinion seals/gaskets.
  • BC Broncos power brake kit with new vacuum assist and master cylinder. Also, new brake lines and adjustable proportioning valve.
  • 1993 Mustang GT 5.0 transplant. Bored .030” over. Ported and polished. Rebuilt by Dave Hiatte Machine Shop in Clovis, CA.
  • New 3G high output alternator
  • New plugs, wires, and rebuilt distributor
  • Wild Horses titanium shorty headers
  • New accelerator cable, speedometer cable, and VSS sensor (Wild Horses)
  • New O2 sensors, thermostat, and water pump
  • New engine wiring harness
  • Rebuilt heater box with all new gaskets, new high volume blower motor/cage, and heater core
  • 3.5” suspension lift and 2” body lift from BC Broncos. Heavy duty shackles with greasble bolts, heavy duty front shock mounts, heavy duty u-bolt kit, track bar riser, new nitrogen filled shocks, all new bushings and body mounts, and CAGE long arms.
  • Heavy duty custom built rock sliders (.25” full wrap)
  • Custom rear bumper with swingout spare tire carrier and high-lift jack mount.
  • Back seat (currently not installed, but as simple as a few bolts)
  • Tuffy lockable metal center console with radio
  • Bikini top
  • Too many other new installed to list
  • Boxes of extra parts….
I have it listed on Ebay right now, http://http://www.ebay.com/itm/11234...84.m1555.l2649
If you want any pics or anything, just holler. Thanks for looking.
For Sale, Built 1969
bob_lafrentz is offline   Reply With Quote
Old 03/19/17, 10:19 PM   #2
thegreatjustino
Red Head Grease Monkey
thegreatjustino's Avatar
Vroom Vroom
Stockton, CA
http://www.ebay.com/itm/1969-Ford-Br...5YzzQf&vxp=mtr
'When my Bronco is finished' is only a hypothetical statement.
thegreatjustino is offline   Reply With Quote
Old 03/20/17, 11:59 AM   #3
bob_lafrentz
Cody, WY
Originally Posted by thegreatjustino View Post
Thanks Justino!!
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Copyright © 1996-2017 All rights reserved. Privacy Statement
