JAFHR
Hello, it's been a long time since I posted. I've got a 68 EB in which I had a 3.5 long arm lift from Jim Cole (Bloody knuckles/Cage) put in, including springs and leafs along with a 3" body lift. I also have a front axle assembly from a Ford F150 high pinion. In order to steer the beast I had Heim system installed. I'm about to throw on 37" tires and wheels. I'm running 513 31 spline axles.
My issue is the front coils appear to be very soft. When I take off, the front end lifts up and it steers to the left. When I let off the gas the front end comes down and a get a bump steer to the right. Its pretty severe, not to mention the radius arm hits my headers. I found out the headers are not the right ones for the set up. I'm real confused as I just spent a ton of money getting it to this point, yet it drove a whole lot better before. I cannot drive it this way. Are there stronger coils out there. Not looking to crawl too much. Just a good daily driver with good manners. I've seen all the coils from WH, TB etc. What to choose.
Help.
Help.
