Thread Tools
Old 11/13/17, 07:52 AM   #1
Galt72
Galt72's Avatar
Galt, Ca
ZF shifting question
Little background, Nearing the end of a 5 yr build. Explorer injected 5.0. I had a NP435 installed CF II clutch and it was running but wanted a ZF. Found one, My son a Ford Mechanic and their master Trans guy tore it down inspected and said it looked like new and put it back together.
The other night my son and I bled the master. I suspect there maybe still some air in it as the pedal is soft and only doing its job the bottom 4 " or so. My son said he could see it pushing on the clutch doing its job.
The next night I noticed I can row the shifter through the gears like butter. There is no difference between the clutch engaged or not. There is no feed back at all!! My question is this normal? I'm use to the feel of the 435. I can't start it as I have no exhaust system yet. I'm scheduled to have it towed on wed to the muffler shop. Not doing that if I have to pull the trans....
Thanks for any advise or thoughts.
Galt72 is offline   Reply With Quote
Old 11/14/17, 12:43 PM   #2
NYLES
NYLES's Avatar
YOU WANNA WHAT?
FREE RUN, MS
Sitting on flat ground it will shift no problems remember its synchronized
'69, 306 EFI'ed, ZF, DANA 44, 4 WHEEL DISC'S, ASTROBOOST, 3.5"SUSPENSION LIFT, 2"BODY LIFT, GLASS BODY, 37" ON MRW, 5.13's GRZZ/GRIZZ , MOSER, STONE CRUSHER, POWER STEERING, BAILIE BILT, DURABACK, RJM
NYLES is offline   Reply With Quote
Old 11/14/17, 02:15 PM   #3
Galt72
Galt72's Avatar
Galt, Ca
Thank you, It shifts so smooth it scared the crap out of me !!!
Old 11/14/17, 02:45 PM   #4
Bitch'nBronco
Bitch'nBronco's Avatar
ZF Swap in progress
El Paso, TX
If you didn't bench bleed the MC and line it may still have bubbles in it. Its a pain to get them all out bleeding it all assembled together. I'm not sure what system you are using to depress your MC from the pedal, but you may need to adjust it out a little so it functions in the range you desire.
Bitch'nBronco is offline   Reply With Quote
Old 11/14/17, 03:13 PM   #5
Galt72
Galt72's Avatar
Galt, Ca
yep, didn't bench bleed it. Read that after I had it all installed. I have the modified stock clutch pedal with the stopper attached to the arm to avoid bottoming out the master. I agree I've got some adjusting still to do.
Old 11/15/17, 12:15 PM   #6
nvrstuk's Avatar
20 gears forward...no reverse!
WA
Why can't you start it? Heck, not like you'll be revving it to 3k just to see if when you push the clutch in you can shift from 1st to reverse without grinding...do it...even if you have to tow it out of your neighbor hood or something...
Guess I'm really lucky I live where I do... although retiree "ranchettes" are popping up...
Strrroker powered... 418 cubes, 518 HP energized with SEFI, EDIS, Trick Flow, Mahle, etc... this brings a whole new meaning to the term "burping the throttle" Still 24+ forward gears...
nvrstuk is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Copyright 1996-2017 All rights reserved. Privacy Statement
Page generated in 0.34510 seconds with 56 queries
