Defreels
Two 1969 Bronco projects for sell. You won't be able to pick and choose you will have to buy them both with all the parts. There are enough parts here to finish them. One has a 6 cylinder in it with three speed on the column. And the other one has a new rebuilt 351w with c4 automatic transmission. I also have an extra frame and a body that I was using to cut pieces out of to fix some rust issues in the other two. One of them has had the tub and frame sandblasted and primed. I also have new floor pans to weld in both of them. The v8 has new c bushings and spring mount bushings, new power steering conversion kit, 2.5" suspension lift, Dana 44 front differential a new painless wireing harness, along with various other things. I bought these to resell so the more I do to them the more I will be asking. For more information call or text 423-539-6233 email defreels@live.com
