Tilt column. From a 1908-91 Bronco.
This came from an automatic transmission equipped vehicle but will work in a manual - this was installed in my floor shift three speed '74.
Ignition switch on the column. Uses a curved eight pin signal/hazard/brake light connector like 74-77 Broncos (I reused the plastic wire housing so it's not included).
Although not shown in the photos, this does include the ignition pig tail that plugs into the side, the ignition key, the signal/tilt function lever, as well as an additional plastic trim piece that goes around the column.
I had this wired into my '74 and everything worked fine. I've recently removed it to install an Ididit.
$300 plus the ride.
$300 plus the ride.
