bronconut73
- Aug 7, 2012
- 9,916
I got my Serp set up including fan/clutch from Sandmann so I am good there. Not ready for EFI yet.
Started to build up my parts list, then took a purchasing break, lol, but got back on it. It gets a little expensive but buying it in stages always helps me slip it past the old lady,....lol
I have a,
Used Explorer ps pump,
New WH Flowkooler water pump,
New DB Electric 4G alt.,
New Damperdudes HB,
New BC 90 degree thermostat housing,
New 3 core aluminum rad. with the Explorer hose swap,
New Visteon Explorer a/c compressor.
From what I have read I will be better off with my used Explorer ps pump instead of a parts store one.
I know I need,
A washer ready to go back on my cam bolt when I remove the eccentric slinger for the old fuel pump arm,
Timing chain cover and water pump gaskets,
(I have a one piece oil pan gasket)
a/c lines adapted,
ps pump lines adapted,
Shroud,
Radiator hoses (stock Explorer?)
Anything else y'all know of that I need to have ready?
Thank you for the knowledge as always.
I have a,
New Damperdudes HB,
I know I need,
a/c lines adapted,
Shroud,
