Starman
I'm looking for the spring that goes inside the two sliding sprocket gears. The assembly is held together with a screw to keep the spring inside. It is an unlock spring.
The warn assembly # is 20990. The hub can be used on a EB dana 30 and 44.
Thank you.
Thank you.
