migs' build thread - A 1970 Bronco ...an ever evolving project
migs
migs
Well, it has been a while since I've been able to do some work on the Bronco, but yesterday I had some time and took advantage of the warm weather. I took her out and blasted the rusty areas on the inner rocker and door posts to see how bad it was and to get ready to start welding in some new metal. cut out the swiss cheese on the lower front area and now the next step is to make some patch panels, clean it up a little more and start putting it back the way it was. this area is a bit complex with all the layers of sheet metal and all, but I like a good puzzle. after that's done I'll deal with the holes in the striker post.
tasker
all knowing of nothing
NH
DOING A great job!! coming down saturday?
migs
migs
thanks man! I would like to go, sounds like a good time. but I still have that recording session scheduled. if something should change though....you never know with musicians.
migs
migs
on the pass side striker post. there was a factory looking plastic plug in there. there was also one on the bottom of each rocker and 4 on the tailgate. looks like they were access holes drilled to spray the protective wax inside the cavities.
migs
migs
the rocker I chopped off was was loaded with the stuff. it does scrape off alot easier than that undercoating though.
tasker
NH
Hope you can make it......damn musicians. :(
dave67fd
Looking good, glad to see you got some time on it. Was getting concerned i hadn't seen any updates. (I should talk lol).
Do you (or anyone) know of a local retailer were i can get bottled 75/25 gas for my MIG135? Not sure what size bottle but would mount on a small welding cart. Guess would be about a 2-3' x 4-6" bottle. Would rather buy a bottle and fill when needed then rent. Sorry for the Hi-jack.
fatboy
Glad to be here.
New Hampshire
Call here and ask for Todd, tell him Pete sent you. Have not been in for a while but my old company did a lot of business with him and I bought my hot wrench and tanks as well as my Miller 135 and bottle from him.
dave67fd
Thanks Pete,
I actually found this site last night thru google. Put in my favs. Figured Derry was the closest place.
migs
migs
so I had some time today to make up some of the small patch panels needed. did I mention how much I love my cnc plasma cutting machine.;D
this is the first vehicle restoration that I have undertaken since I've had it, and this way is so much easier and faster than dealing with hand shears and cut off wheels, especially when working with 18 and 16 gauge sheet.
I used some old dirty srap pieces I had lying around. here are a couple of pictures of the final product. first how they look out of the plasma, then after a short trip in the glass bead cabinet, and finally just a quick mock up. just have to do a little final trimming and punch some holes for some spot welds and then put the puzzle back together.
migs
migs
fully automated. It is a retro fit table utilizing Dynatorch controls, servo motors and software. a Hypertherm 1650 provides the plasma.
dave67fd
Wow, you could almost build an EB from scratch. :cool: I'll take two.;D
How many sq.ft. does it take up?
migs
migs
The cutting area is 5' x 13' plus figure a couple feet around that and also the exhaust ducting and blower.
the plasma torch will severe 1-1/4" thick steel plate. I can get a nice cut edge up to 1/2" thick after that you start to get some noticeable angled kerf action going on. also have an O/A torch head that can be swapped on, but I never use it as it's more of a pain and we dont need it for the things we do, But it will cut up to 9 inches thick.:eek:
dave67fd
That is a pretty sweet unit. We have a Laser shop in Danvers do all our cut-outs and watching those are pretty amazing. The Plasma must be just plain ol' fun to watch:cool: and hear.
migs
migs
It's alot of fun until it's time to clean out the tray.:( it's taken me a while to master it and fine tune it to be able to make some pretty nice accurate cuts. it will never cut as nice as a laser machine but it also doesn't cost a small fortune to own.
