Bucky66
- Joined
- Jun 20, 2010
- Messages
- 550
Not really sure about the pricing. Advertise it as the under construction crawler build.
OR
If it runs that good, I would do like you are saying and rid it of the body lift and cut out all the tubing you can, remove the windshield gasket and put new one or clean all the overspray off. Clean up the inside the best you can. Respray the dash. Keep the bumpers. Hit CL for some cheap EB seats and wheels (bullet holes )and tires. remove the door inserts since not lining up. Couple other odds and ends. Also show what is under all that diamond plate.
Sounds like a good weekend with a few bronco guys.
Also, It has been abused, so take that eyebrow grill off and put on a different one if you can find one on the low dollar. If you have the paint to match to make it like the rest of the truck. You could probably get a few extra coins if you sold that on the side.
This being said, I know no time for it but if you can...
I still like it. Its an EB. Good luck with the sale.
OR
