- Joined
- Jul 31, 2001
- Messages
- 8,605
October 19, 2015
Back at it tonight...last modification to make the pump fit on the '98 Exploder sending unit assbly. I cut the mounting brkt off appr 2" from the base, then I found that nice rust-colored pc of 16ga angle and formed it to fit in a position so that it could be welded onto the original remaining bracket and where it needed to be so the pump would be directly below the pressure line exiting the tank. Couple hours of dinking around but I had less than 1/8" clearance btw the baffle in the tank and the new pump mounting location on the fuel tank sending unit assbly bracket. Make sure you use submersible rated hose if it's in the tank...
