Handy things.
Package of light weight gloves.
Short adjustable stool with wheels.
Knee pads.
Creeper.
Two trouble lights.
Four aluminum jack stands. For under the axles. I need light weight things.
At least two high jack stands.
An engine hoist. Can be used to lift the front or rear of your Bronco then put jack stands or/and blocking under the frame for safety.
A good shop vac. Get an extra hose or two so you don't have to drag it around.
Two or three fire extinguishers.
I think you all should have a water based/air pressure extinguisher (I don't have one
). Use around welding/cutting work. Not messy. Use to put out fires or cool hot metal. When empty, just add water and compressed air. The bad- around $100.00 +/-. One time cost, but always there if you fill it.
An air compressor. Look at your future needs. Are you going to run air tools, paint, blow out dirty parts.
