guidoverduci
At first I thought I had a belt issue, but now it seems the squeak only comes when the clutch is pressed.. any ideas?
Learn to toe-heel on those downshifts.
I was asking because if the thrust bearing goes bad on a small block (and they do) the crank will shift forward from the load of the clutch. This binds up the rod bearings. The binding will make for a lower idle when the clutch is pressed. If you can push the crank pulley in and out it is bad. The clearance when good is only a few thousandths of an inch, which you might feel but will never see. When it goes clunk-clunk and you see it move over 1/16" it is bad.
Well, even with the fact that I've never had one do that, I'd have to say that's a bad throwout bearing.
Unless you find something that is touching linkage, or if the sound is coming from somewhere else, it's a classic throwout bearing noise.
The part where it makes the noise, but to a much lesser extent while the clutch is not being pushed, still seems to indicate that the throwout bearing is lightly touching the pressure plate and still spinning.
Does it ever go away? Like if you're idling for awhile, will it eventually stop? Or when you first fire up the engine without putting your foot on the clutch, does it make the noise?
