Front Center Caps For Method Wheels
Retoohstyoh
I just purchased a set of Method standard 301 machined finish wheels. They have a 108mm bore. The caps included are not designed to be drilled out and look right. Any suggestions on front caps or just paint the hubs black? Any pics of what others have done would be a great help. Thanks
  • MR_301_18x9_Diamond_Cut-1000_65209614-d3a2-4438-b4d6-71cc26a7995c_800x.jpg
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
Is the center cap plastic or metal? I'd get the center machined out to fit the front hub. See if you can remove the center part with the wording on it.
rguest3
The Method wheels I have had before had a center cap (Push on from the front) where the top of the cap can be unbolted. Unbolt top of cap. Carefully grind off the tabs that hold the bolts on. (Now it looks like a sleeve or Open Cap) Reinstall.
Do you have this style of Center Cap on your Method wheels?
The older style of center caps mount from the back. These will most likely not work.
R
Retoohstyoh
I saw those were available. Not sure, but maybe that's what everyone is using. I was looking for something that fit a little tighter around the 3 1/4" hub. I guess I could get a "4 1/4" closed cap and drill a hole to size.
R
Retoohstyoh
I have the push from behind caps. The design with the bolt pattern will not allow me to drill these out.
