NP205 side mount bushing, what are you guys using
fordguy
I saw it in a thread somewhere, but cant find it now. I will make my on mount that bolts to 205, then drill a hole thru frame for a bolt to hold it on.
F
fordguy
poked around on their website but not see them, if you find a pic or link please post. thanks.
AxlesUp
Collierville TN
from the previous owners build thread on mine.
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
I used the stock steel mount, ran a bolt thru the frame and put a body mount in between the frame and the plate that bolts to the side of the t case
F
fordguy
that was my thinking, but I have not found any single body mounts in poly, everybody sells them as a kit.
Bitch'nBronco
Loose Cannon
Havre De Grace, MD
Maybe try a parts store, they usually sell random energy suspension stuff. Or try an wanted parts add on here for a spare Bronco body mount. I had extras from my extended cab F250, it had a few extras for a crew cab. Or I guess you could try a hockey puck lol
F
fordguy
another pic of the second part of the "cradle" for the np205, there will be two pieces between these pieces that runs parallel with the frame. hope to get everything mocked up and coped this weekend. I have gussets that fit the bushing and the pieces that are attached to the 205.
F
fordguy
studs will be welded on the pieces that will run parallel with frame for a skid plate
