migs' build thread - A 1970 Bronco ...an ever evolving project
broncoitis
Well Brian, the engine is lookin really good! Hopefully it will be back on the road soon. Dash looks great as well. Curious what you did to the fan clutch to clean it up so nice. CLR???
fatboy
Glad to be here.
New Hampshire
She is gonna be a beauty! You will have to rename her as I do not think she will fit the current name I gave her when you are done, a totally different personality! ;)
migs
migs
Interesting trac bar riser bracket, did you make that one?
Yes Tim, I do make those. somewhere way back in this build are the pictures when I was designing it.
might want to check the angle on the track bar too ;D
I thought it gets connected to the tierod??.... Or maybe I'm adding a drop steering box bracket. did you ever think of that?;D:p
Thanks Rob, just media blasted it and paint.
Oh great..... another decision to make%);D;D
migs
migs
test fitting the serpentine set up before I clean up and paint some of the components. replaced the bulky dirty stock explorer power steering pump set up with the bracket and heavy duty pump kit from WH. fits pretty good and is much cleaner with more space all around.
broncokak
Hmmm, may need one of those canned ham brackets. Very nice work!
Sent from my SM-G900V
migs
migs
Thanks Ken, it's starting to just fall together now...
Reassembled the pedal box, here's a before and after pic. then installed along with the E brake pedal and started hanging the dash.
migs
migs
Problem solved
tasker
all knowing of nothing
NH
you are going to feel like your playing the Piano driving it! :cool:
Slednut10
Guru? That's funny!
He's just messing with us- it's already built and he's driving it;)
migs
migs
well, since my feet will be pretty busy maybe I'll go with just a hand throttle!;D
a little more progress.... disassembled a steering column to clean up and rebuild. have a little fixin to do on the shaft where it wore into the bearing.
migs
migs
and started on the design and prototype work for a new coil pack mount for the explorer engine.
Slednut10
Guru? That's funny!
You just can't leave anything alone, can you?%););D
Nice, B, can't wait to see this rig on the road!
