Ben's 73 Build Thread
Bferrari
Bferrari
Almost there! Have spent quite a bit of time fitting, grinding, welding, etc. Just have the two floor front pans and the drivers rocker to weld in and I am complete with this phase. I am very exited to be rust free!
mjramacher
nice work ben everything is coming along very well I like the wiper mod I really wanted to do that but I gave up to much stuff behind there have you figured out how it will all work if so I might be interested in some pointers on doing this.:)
Blue Bastard
I hear that Ben. The metal work is a real time consuming messy phase. Looking real good
englewoodcowboy
Lick Creek Restorations
Ben you started out with a bronco in much better shape than mine was... I am glad to see someone else plugging along at it, I remember those days of things that went in to make it look like a lot was done in a short amount of time, now I am still fitting tweaking and welding and grinding all to fill holes I won't be using or weld something I missed. Just be sure to take your time going over it, I have found a handful of rosettes I missed, probably when welding a pan and bouncing around to no heat soak things and in excitement did not look back. Just be sure you check everything before you splash it in sealer. I can say I am rust free but the wedding and grinding take a lot longer than I originally anticipated. Good work my friend!
mattyq17
Looking good Ben!!! I might have to make it over to your shop next week to check it out if you will be around.
Matt
driveshafter
phoenix az
driveshafts
ron at maestero muffler and driveline here hey call me if you need any transfer case yokes differantal yokes or drivelines im a full service shop[ and i deal with broncos daily i specialize in high angle and modified vehicals from wild to mild 602 997 0906
Bferrari
Bferrari
Got the passenger pan welded in tonight ... one left to go!
englewoodcowboy
You know I cant help but wonder if it is physically possible to own a bronco and become iron deficient.....
Bferrari
Bferrari
Getting closer! Got the clutch hole welded up in the drivers pan and the pan welded back into the bronco. Repaired the couple spots that needed attention with the inner rocker and began fitting the rocker. I took the body off the rotisserie and put it back on the frame with new body mounts. Wanted to check gaps and set the rocker prior to burning it in. I am pretty stoked right now, after all the surgery, the door gaps are great! Stay tuned ...
FBSixtyEight
Oley, PA
Nice work! Those welds look all too familiar... Haha, it always feels good to see it come back together again, keep it up!
Bferrari
Bferrari
Finished welding up the rocker panel and then installed and set both doors. The gaps have turned out pretty good so it should make life easier when I start body work. I then started carving up one of the extra fenders, getting it ready for the graft. Next I cut the rear quarter and am currently melding the two together. So far it's going smooth, can't wait until it's done so I can see the finish product.
Bferrari
Bferrari
Was able to finish the passenger side rear flare today. Had a special helper with his tool belt assisting in the effort! I utilized as many factory bends and radius sections as possible, turning it into somewhat of a quilt. Got her all burned in and primed so it's done for now until I start the body work. Drivers side is next.
Bferrari
Bferrari
Spent a couple hours fine tuning the graft, getting it ready for body work. Pulled it back off of the lift to turn it around so I can get better access to begin on the drivers side.
Here is one final look at her being factory!
