- Joined
- Jun 17, 2004
- Messages
- 359
How long did that take?
I know the drop accommodates raising the tank as high as possible against the floor board, but is it's depth also based on the depth of the Explorer set up you are putting in there?
lost ~1.2 gallonsHow many gallons do you think you lost?
Good points DD, I havnt really looked at others but I sure it is possible, really only thing that would need to be changed would be the press reg, so it would have correct pressure, I think most if not all of the factory pumps are capable of 100psiBe nice if the module was easily extendable. I wonder if there are other, similar design modules that happen to be taller because they're fitted to larger tanks in their original applications?
Such as a full-size pickup, or even a van, rather than an Explorer?
What's the price on that sender? You should be able to buy the correct sending unit straight from BC (or us for that matter) and not have to modify it. Just drill the plate maybe?
Or, instead of the traditional sender and removing the disc, simply cut a round hole and install one of the new senders that comes with our new M1A1 tank?
How tall is your tank in that area of the plate? If it's between 11.5 and 12 inches, that sender will read right down to the bottom.
At $79 bucks (#9668B), it's more expensive than the standard one. But probably easier to match up to the plate, odd shape and size tanks and not interfere with the pump and pickup too.
And maybe even get more consistent gauge readings at the same time?
Paul:
Couldn't find that PN on your website. Is it not there yet?
Thanks,
Todd Z.
Hey Todd. Sorry I bailed out for awhile.
Nope, not on the site. Might not be at all, at least for now, since it's not really expected to be a separate part series unless there is more demand for it. Hence the "B" as a suffix, indicating it's part of another kit that can be tracked in the computer.
If you want to know availability and current pricing, you'll just have to call in with that part number in-hand. And if more info is needed, such as what all it comes with, someone can pull it off the shelf and take it out of the box and check.
Kind of a shame, as it would be nice to have it not only listed, but detailed out on the website for our study.
Might happen sometime of course, but for now you just have to ask about it by number.
