Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 03/19/18, 08:25 AM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Beefy Dana 60 Steering options @ Ruffstuff!
Big bad-ass steering is sort of our mantra here at Ruffstuff.
We are proud to offer a wide variety of HEAVY DUTY
steering options for KINGPIN 60s!
First, we have stout high-steer arms that use a threaded
pre-load adjuster for those who are going spring-less.
These arms feature GM 1-Ton TRE taper for the tie-rod holes, and a larger reamed hole to
support the high angle drag link ends that allow your axle to travel further
without binding or exceeding the maximum angle of the DLEs.
We ALSO have arms that go over a stock spring cap for those folks wanting to keep the pre-load springs.
*Note, these are an earlier design, and come with Standard TRE Reaming in both tie-rod and drag link locations.
This of course is easily reamed out, or drilled for heim joint use.
Both styles of high-steer arms are drilled for after-market 5-stud knuckles,
however they work just fine with factory 4-stud knuckles, the 5th hole is just empty.
Now lets talk about how we can link all the moving pieces together,
We offer the same 3 different styles in both spring and springless:
1- Cross-over - in this kit you would be using factory TRE locations on the knuckles to attach the tie-rod, and it would come with one highsteer arm for the passenger side knuckle to attach the Drag link, as well as a new king pin cap on the driver side knuckle.
2- Cross-over + High-Steer - This comes with high steer arms for both knuckles, and you would connect both the drag link, and the tie-rod to them. Big benefit of moving the tie-rod up, and out of harms way (as long as you have the clearance to oil-pan and frame).
3- High-steer Y-Link - This kit attaches the tie-rod to both high-steer arms, however the drag link connects to a tapered hole on the Tie-rod itself (instead of all the way to the knuckle). This is often a benefit for narrower vehicles with link suspension, that have a shorter pan-hard bar, the shorter drag link helps with steering geometry and bump-steer.
You can find all of these kits, as well as individuals or packs of D60 accessories right here:
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 03/21/18, 04:40 PM   #2
mofoco1
mofoco1's Avatar
Broncos Rule! And by the way if you don't love America no ones keeping you here!
Clovis, CA
eBay: mofoco1
Are you doing any specials for tax season?
mofoco1 is offline   Reply With Quote
Old 03/26/18, 10:50 AM   #3
Gravel Maker
Quick with a Laser!
Sacramento
I'm not sure if we are at this point, my marketing team hasn't told me one way or the other, but I will say we historically have, so....
If you are in a hurry though, the BRONCO discount code is good for 10% off all the time ;-)
Old 04/25/18, 11:01 AM   #4
Gravel Maker
Quick with a Laser!
Sacramento
Beefy pieces that are easy to make work for your rig!
Old 07/11/18, 08:31 PM   #5
Gravel Maker
Quick with a Laser!
Sacramento
However you need it!
Old 07/30/18, 10:21 AM   #6
Gravel Maker
Quick with a Laser!
Sacramento
Get the parts you need to fit your project! They are all a little unique, and we're happy to help you figure it out!
Old 09/07/18, 10:24 AM   #7
Gravel Maker
Quick with a Laser!
Sacramento
Get it done the way you want!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.29787 seconds with 63 queries
