00gyrhed
- Aug 3, 2006
- 2,428
OK, first I do not need to be sold or unsold on sealers or internal balancing. I was researching the use of air soft pellets as a cheap internal balancing agent on the Internet and I found several products that claim to balance as well as seal.
I have 34X10.50X16 LTB SS on my Bronco. It hops around too much to drive much above 60 MPH. I am building this Bronco to be my hunting, fishing, mud rig. I need to be able to make long highway trips and 60 MPH is not acceptable. I have been to several shops to to have the tires spin balanced. Tried the Hunter system that mimics a loaded tire as well. I am going to go with some type of internal balancing. However these products that claim to seal leaks too are interesting because of these sorry mesquite trees here in Texas. The following products claim to do both:
1. PJ1 Balance Plus
2. True Goo Tire Sealant
3. Ride On TPS (Tire Protection System)
4. Bars Tire Stop Leak.
All of these products claim to be easily removable with water. I have run internal balancing before so I know it works. I have also run sealants. The only problem with sealants has been that the vehicle wasn't used much and the tires lasted until they got too old to put on the highway and the sealant hardened in the bottom of the tire.
Any one here in the forum ever used any of these 4 products? Some are comparable in price to the dynabeads.
1. PJ1 Balance Plus
