I looked at your perches that said 8.8 9" or D60 3 1/16" -3 1/4" as per your details on the regular Ford perch:
This is a new variation on one of our fairly basic items, but it isn't quite that basic. Anyway, here's what you want to know. These are .25" (1/4) HR P&O Steel Plate, CNC Laser Cut and then Folded on a 290 ton CNC Brake to final size. Length is 7.75" to help control axle wrap and 2.5" wide to provide a stable platform. They have 3 spring pin mounting options so you can adjust your wheelbase if you wish and are cut to fit a 3 1/4" axle tube but they have 3 - 1/16" nubs so they fit a 3 1/8" (Small 9") tube out of the box, grind off the 3 tiny nubs and they fit a Ford 8.8, D60, and the Ford 9"(3 1/4"), pretty simple. Sold in pairs.
Price: $35.00
Rating: 5 out of 55 out of 55 out of 55 out of 55 out of 5 4 Reviews Read
Part Number: 88PERCH
Shipping Weight: 7.00 pounds
Quantity:
So the 3" would be a bit small. So can we expect a large ID perch to use out of the box for the Fords or has that been nixed? Thx.
