I got a 66!!!!
Bajabrewer
Bajabrewer
A couple more pics before I tear into it.
Bajabrewer
Bajabrewer
Well I think this might as well be my build thread. More pics as we pulled the carpet and roofing material out. Some of it's solid - some not so much. It needs a tailgate & lots of patches but the main floor panel is surprisingly good. I'll post the rockers, floor pans & more as I get to them, I know they need doing. I think the green doors & hood probably came from the same donor truck. Last pic is the pile of crap I pulled from the drivers air box.
Bajabrewer
Bajabrewer
So I got some time to work on this one & I started with the kick panel. The PO covered it with some heavy metal pop riveted on - when I peeled it back guess what I found! :D I figured the vin tag was long gone. Then I tackled the spray foam over the front window. %) It just trapped & held water - the top front edge may be shot. :p I also got some 31x10.5x15 mud terrains mounted - I like the looks better with these tires
sprdv1
REBEL
One step at a time right.. lol I like that.. "cadaver" :)
Bajabrewer
Bajabrewer
Time to start rust repair
Here is the start of replacing the rear rail. As you can see by the pics it was failing & needs attention NOW to get the Bronco roadworthy. I drilled the rivets that I could see(that were still holding anything) and using an air chisel I separated the old rail from the bed floor & tailgate posts. I'll need to get some "Frame Savers" & weld them in before I install the new rail.
Bajabrewer
Bajabrewer
After getting all the old rail out I test fit the new one & the bed corner pieces & I think they fit really well. I need to tweek & measure some before I weld but I'm pretty happy with it at first glance. After I get the new rail located & maybe tacked in place I plan on cutting the rusty bits out & fabbing some patches to make it solid again. This is going to be a trail rig with patina so keeping it all original isn't going to happen. The last pic is the tailgate when I stood it on end & let the rust run free. Good thing I already have a replacement for that!
Bajabrewer
Bajabrewer
Rear channel and bed rear corner pieces welded in. Last Pic is before for reference. :eek:
