Radio delete plate.
Acknud
Morganfield, Ky
I have a hole in my dash from when an aftermarket radio was installed. I no longer have a radio so I wanted to put a plate there. I was thinking of maybe something with a clock since I have no clock. I'm not very creative. Anyone have any ideas on what I can do? I can post measurements and a pic if needed.
RODRIG3911
Tucson
You could cut a patch panel and weld it in and it would look like it never had one.. You could also cut a larger piece of sheet metal and drill holes towards the corners and mount it on with rugid looking screws and mount your clock on that... I myself made a cover out of aluminum with rugid looking screws and then mounted 2 4" speakers and moved my radio in the center console.. I'll attach a picture in a bit. I also have a beer opener on my dash that would be another idea for you lol
RODRIG3911
Tucson
Here's the pictures of what I did
Lawndart
A PO cut my dash as well. I found a Ford radio delete plate and painted it to match; hardly noticeable. P/N = E69Z-1104371-B
half cab
Guru Bronco
I been looking for one of those ever since you posted that in another thread a few yrs back.
JSBX
You could cut a plat to fit and install switches in the plate or try to find a switch panel that will cover the hole.
Scoop
Have Bronco, Will Travel
Cuchara, CO
I've made several "radio delete plates" over the years. Smooth polished aluminum, brite diamond plate (LOL), padded black faux leather, wood, - there are plenty of possibilities. Good place for a switch panel or CB, as mentioned. Also a good spot for a recessed cubby hole. And I've welded up a couple to make a factory looking radio delete dash. I don't have pics of all of them.
Crush
Greenbottom, WV
that ford plate was in a lot of the cheapie model 86-88 rangers. my 86 ranger had one and I cut it to mount a new stereo. worked out well but wish I had gone and taken as many as I could from the junk yard and taken all the ones my buddie that installed stereos professionally had laying around his business workbench
Acknud
Acknud
Morganfield, Ky
I wish you had too! I need one.
sprdv1
REBEL
Def be cool to have one of those...
