Bump for bigj, and a question. Did any one use this bracket in a half cab? I would think it would only allow enough room for just the 2 inch setting holes. My bronco came as a "Bench" seat full cab. Presently using stock buckets seats. So I used the 4 inch rear left (driver's} side bracket hole, secured a long bolt down through the seat bracket first, then bracket, lastly into the factory welded nut{original used to secure rear left driver's bench seat}. I also needed to drill a new hole for the right front side. Using the front right side bracket hole to mark the location, I drilled into the seat platform. The hole actually goes through the crossrail support. Lastly using a long bolt, washer and nut to secure the seat and bracket. The driver's seat is only held on by the bracket and 3 bolts, no need for a 4th hole to be drilled into the right side rear platform, Plenty strong enough using bigjhoov's bracket. So I am wondering if I ever get a half cab top, will I have to move the buckets seats to the 2 inch holes settings, in order that the seats are not hitting the bulkhead or bottom of half cab. Thanks, Slim.
