I can’t wrap my head around this. With the stock radiator I would reach 220-234 if I was in traffic for hours. With my Ron Davis, I hit 238 in 10 minutes. The moment I get to 15 mph for 30 seconds or so the temp drops so fast to 209 or lower. It is 70 degrees out today. Is it just from my 5 blade fan? Things do seem worse wth this radiator. But then if I switch back, I’m out $600+
Edit, well the temp just sky rocketed to 250 and I’m boiling out my cap now.
I think you are fighting issues with both the shroud and the fan.
The fan you have is the wimpiest of all the V8 Bronco fans. I would definitely replace it before changing anything else.
I noticed in your pictures that there is a large gap between the shroud and the edge of the radiator, at least on one side. I would close any gaps off so the fan doesn’t pull hot air from under the hood thru the shroud, bypassing the radiator. All those gaps can reduce the amount of air actually pulled thru the radiator.
At idle, you could also have hot air recirculating back under the grill and getting pulled back thru the radiator. A bigger fan moving more air will help with that.
If you stick a sheet of paper up to the grill at idle, the airflow should hold it there. If not, you have an airflow issue, not a radiator issue.
