FiTech Frustration! Fuel pressure takes a dive once hot
airman
kyle, super nice find! Was a replacement OEM ford part from 81-96.
MonsterBIlly
My shut off issues start when the temp is 205 or greater. Usually in traffic. When it shuts off, i pull over and lift the hood. If i sit for 3 or 4 min it fires back up.
I will ad a insulating spacer and see if it helps. I wont have a problem until next summer.
Also, my Fitech display dies. Its the second one. Fitech already replaced it once when the button quit working. Now this one wont light up at all.
garberz
Bronco Influencer
Conejo Valley, Ca.
My buddy’s had the same issue, once it got up to 210*, it would shut down and the tune would reset itself to default.😡 Never could figure out what the exact cause was, although I know it was heat related. He’s now running an Explorer 5.0 OBDII system, problem solved!
Mark
bseager
I had issues with my handheld not turning on. FiTech sent me a new handheld and cable and that one wouldn't turn on either. Ended up having to send in my whole unit in for warranty work. Turned out to be an ECU problem and FiTech had to replace the ECU in the throttle body.
Sent from my SM-G892A using Tapatalk
I don't know why they are doing warranty on the hand held controller. The is clearly the ECM on the throttle body that is flawed, shutting down with fairly normal operating temperatures.
M
MultiBeast
NC
Maaaan I hope that’s not what I’m dealing with. I got the summit pump airman was talking about. Hey airman, are you using thoutlet fitting that came with it that has the check valve in it? Seems pretty restrictive.
M
MultiBeast
NC
I haven’t had any issues with my touch screen. So crossing fingers on the bad fuel pump. If the thing shuts down when it gets a little warm, then I will never make it through an NC trail in the summer. Climate change is real!!!
airman
I remember thinking the same thing but left it in anyway. I don't think we are using half of what this pump can do. I'm not concerned with the restriction for mine. You may need an AN adapter to fit your fitech pump lines.
Also, I always thought your trouble was the pressure regulator. If you lose pressure again, change it. As cheap as they are I carry a spare.
airman
Airman, is that breaker necessary? Isn’t there a fuse in line already?
So, As I said, i have two tanks and a stock switching valve for the supply and the return. I sometimes set that valve in the middle as a theft deterrent. I did this with the HP pump and forgot to turn it back to allow flow, instant pop fuse. No problem, took radio fuse and went along my way. I put the breaker to save me from spending my retirement on fuses. fuse is fine.
M
MultiBeast
NC
I gotcha. Thanks for your help man. Finally have a break in dad duty tonight, putting in new pump after work. Went ahead and ordered pressure regulator as well.
M
MultiBeast
NC
Ok, put that summit pump on as mentioned above by airman. And the fuel pressure is back 100%. And it is SO much quieter. Anywho, ha you thought this had a happy ending, it is still acting up... It runs like a champ in neutral but driving under even the slightest load it, at operating temperature it still is busting up. Keep in mind it ran fine up until about a week and a half in of install. Regulator on the side of fitech next? Or reset fitech?
Watch the fuel pressure as it breaks up. Is the pressure dropping off or staying high?
How fresh are the fuel filters?
airman
What does "busting up" mean? like starving for fuel? Are you running the pump straight from the FiTech (orange wire) or are you using the orange wire to operate a relay? I think both will work (i have done both) but I'm curious. Also, please change the regulator. I'll buy you one or paypal you $25 if it doesn't fix this. I just can't watch anymore ;-)
M
MultiBeast
NC
Yes like it is starving for fuel. I’m running the pump straight from the fitech. Orange wire to + of pump. Hahaha, hilarious airman, it’s in the mail headed my way. Hopefully here tomorrow! I’ll try that then I’m resetting fitech
I don't think you should ever run two regulators in one line.
Even if one is acting up, you fix that one instead of adding another.
At least that's my take on the subject.
I believe some have tried two regulators simply to reduce pressure from an EFI pump to run a carburetor, but that's a different subject.
