377
Hello,
I am wrapping up refurbishing my gauge cluster and ran into a couple of questions. I installed WH's Precision Electronic IVR and have one small question which post does the ignition feed go to coming from the wiring harness. One post is a female spade post and the other is a male spade post on the IVR my other question is I replaced the factory ammeter gauge with one of WH's voltage gauges. To wire it I just need to attach an ignition feed to the post marked positive and ground the negative post to the cluster housing? Thank you in advance for helping me out with this.
