True North
- Joined
- Oct 22, 2008
- Messages
- 86
The stock bump stop mounts to the top of the track bar riser, correct?
You can basically build a spacer - a friend did that using scrap round tube that he had. Basically giving yourself a new mount surface that's around the height of the WH riser bracket.
I run CAGE radius arms on mine and put bump stops on the frame, such that the radius arm comes up and contacts my bumps there, limiting my up travel.
Both have worked very well for us!
Hi, I hope the Trac bar bracket does not become the bump stop. Good luck
I didn't use the top hole, for that reason. I cut the top portion off and installed the bump on the factory mount. I just needed to notch the rubber and plate a bit.
Mark
P.O. installed the track bar and riser and it drives great as is. Any reason I shouldn’t drop it down a hole? Hate to mess with what works.
That’s exactly what I ended up with B Ron Co. It should be fine. Thanks guys
What is your distance from the top of the bump stop to the bottom of the frame?That’s exactly what I ended up with B Ron Co. It should be fine. Thanks guys
My bumps are in the coils.
Mark
