Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 05/18/17, 06:49 PM   #1
Digger556
Digger556's Avatar
What's your favorite style of accessory switch/panel?
Lots of people use the Carling-style switches, but I was wondering what's your favorite style of switch or control panel?
Examples:
Megasquirt EFI 351W, ZF5, AtlasII, full widths, ARBs, frequency-tuned linked suspension, 37" KO2s, full cage, bumpers, etc.
Full Build
Digger556 is offline   Reply With Quote
Old 05/18/17, 07:31 PM   #2
Dlish
Philly Burbs
I like the last two pics. Where from?
Dlish is offline   Reply With Quote
Old 05/18/17, 07:35 PM   #3
sanndmann3
sanndmann3's Avatar
351W Detroit Lockers
Detroit
last one looks like 19 mm buttons I bought on ebay...
sanndmann3 is offline   Reply With Quote
Old 05/19/17, 08:59 AM   #4
Crush
Crush's Avatar
"It's better to be dead and cool, than alive and uncool."
Greenbottom, WV
eBay: 5.8Bronco
I have been using stock switches. Headlight switch for accessorie lights. Park position for one set. Headlight for the other and then can use dome setting for a third. The factory dash hazard switch is a simple pull on oush off and can use it for anyhing else. Makes it all look factory
76 Special Decore options are undecided it is a bare canvas. 77 Explorer with Special Decore Group, 5.8,M5OD 5 speed, 3.5" rancho lift and 1" wild horses body lift, cut fenders, original 15x36x15 Dick Cepek Fun Country tires and custom early 80's interior.
Crush is offline   Reply With Quote
Old 05/19/17, 10:18 AM   #5
sykanr0ng
sykanr0ng's Avatar
"You say overkill like it's a bad thing"
Greeley, CO
That's the way I'm going too.
Making it look more like factory installed than something from the space shuttle.
The gas gauge switch is a neat three position switch.
Though a few switches a bit like in the last pic might be used individually, if they can look enough like the brake warning light to fit in.
... I've got skills, ingenuity and no regard for maintaining any kind of historical preservation or authenticity...My Dad called that sick and wrong
www.coloradoclassicbroncos.com
sykanr0ng is offline   Reply With Quote
Old 05/19/17, 10:20 AM   #6
Skiddy
Skiddy's Avatar
Lookin at yer booger welds
Shawnee, OK
I really like the "landing gear"
Tried True Ford Blue RIP my brother Mstark
74 Bronco with Mustang 5.0 EFI w/painless harness, C4, 4.56 gears, D20 twin stick, 35's, 2.5" SL, 3" BL, rear spool, Grizzly front locker D44, full cage, 5pt harness. bla bla
Skiddy is offline   Reply With Quote
Old 05/19/17, 11:00 AM   #7
Yeller
Yeller's Avatar
Rogers County OK
These have recently become my favorite. Not cheap, and certainly not "factory" but you can configure them however you want, everything is canbus so no fuses, relays or other wiring problems to worry about, makes the install so clean and easy and if you have a problem its easy to find and if you want to change it its not a nightmare. We've been using them on sidexsides, the savings in labor is enough make the difference in total price.
http://www.4x4spod.com/product_p/8-800-hd-uni.htm
Driver of the Broncno
The bus I ride is so short it is a yellow Smart Car full of squirrels, monkeys and clowns.
Yeller is offline   Reply With Quote
Old 05/19/17, 07:21 PM   #8
Digger556
Digger556's Avatar
I'm glad to see this style of control gaining popularity. Still wish the switches themselves had a little more style.
Full Build
Old 05/20/17, 07:23 AM   #9
Yeller
Yeller's Avatar
Rogers County OK
Most definitely agree about style. I've been wanting to sink one into a console with a flush self lifting tap to open cover, or mount it to the cover. Would be a cool clean touch that is hidden until you need it
Old 05/20/17, 05:12 PM   #10
Jdgephar
Jdgephar's Avatar
Look over there! A Bronco!
Southwest MI
'68 U15, time, $$, 302 full roller, 3 speed, 33's, D44 w/power disc brakes, PS
'72 U15, time, more $$, 347 full roller, TL 4 speed, 35's, LS 4.11 front/rear, manual disc, Duff arms, PS
Jdgephar is offline   Reply With Quote
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Copyright 1996-2017 All rights reserved. Privacy Statement
Page generated in 0.37449 seconds with 56 queries
