Early Bronco Vent Window Repair
admin
Administrator
Just your friendly, neighborhood webmaster...
Phoenix, AZ
Tech article by Bronco-Brian
Transform your broken pivot base back to stronger support than OEM without using rivets. This job takes about 10-minutes once the window is free from the outer housing.
IMPORTANT: Before starting- protect all glass using heavy paper or cardboard so no sparks or weld debris (berries) reach the glass! Wrap the glass and tape it all down tight. Do not remove glass from its steel frame.
Read the rest of this article
