Thread Tools
Old 08/09/18, 08:28 AM   #1
Pops68
Bronco Rookie
Pops68's Avatar
Best looking SHITHOUSE in Forest County, Pa
Bazetta Twp, Ohio
Shifting to 4 x4 low and out
Been a while since I have been in 4x4 low range......
Just want to make sure I got the proper procedure to shift into it and back out to 2 hi.
5 speed with twin stick T transfer case:
Tranny to neutral
front axle in neutral
shift rear axle to neutral then to low range
shift front axle to low range
tranny into gear
back to 2 hi:
Tranny to neutral
front axle to neutral
rear axle to hi range
tranny into gear
Right??? If not, please give me the correct sequence so I don't screw it up!!
Pops68 is offline   Reply With Quote
Old 08/09/18, 10:00 AM   #2
byson1
byson1's Avatar
Nashville
I just put the transmission in neutral and shift. If there's a little drag on the clutch plate you may want to push the clutch in to keep the TC gears from grinding some but that's about it. The vehicle does need to be stopped. You really can't screw it up.
byson1 is offline   Reply With Quote
Old 08/09/18, 11:14 AM   #3
Pops68
Bronco Rookie
Pops68's Avatar
Bazetta Twp, Ohio
thanks for the reply
Old 08/10/18, 03:46 AM   #4
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
I got to do all the above sometimes for in and out.. so darn finicky lol
sprdv1 is offline   Reply With Quote
Old 08/10/18, 11:49 AM   #5
JohnJohn
JohnJohn's Avatar
77 Ranger Frame Off
Richmond, VA
Dont forget to lock you hubs once you are in 4 wheel. Also unlocking them before trying to get it out of 4 wheel also helps.
77 Ranger 5 year frame off nut and bolt restoration by me with EFI, 4.11s, Cage 3.5" lift 2" body lift, MTZ 35s on 17" Allied Monster Beadlocks, Duff Long Arms, BC TRO, Kiser Riser, Protofab bumpers, Warn winch. 1970 Trail rig with 37's on Trail Worth Fab H1 beadlocks, long arms, 302, C4.
JohnJohn is offline   Reply With Quote
Old 08/10/18, 03:10 PM   #6
SteveL
Super dick
SteveL's Avatar
66 &72 w/351, 4spd, 4whl disc.
Hawthorne, ca
Pretty much tranny in neutral should do the trick. Hubs locked don't make a difference but it can make shifting the t-case tougher if bound up. Rolling forward or backwards a few feet can help it unbind. I've had to kick mine out of 4-high when it was bound up.
SteveL is offline   Reply With Quote
Old 08/10/18, 03:26 PM   #7
hammer189
hammer189's Avatar
1976 Ranger
Atlanta
Don't do it on concrete or where the wheels can"t slip. It will bind up and possibly break something. And it's hard to get back out of 4 wheel drive.
BD Fiberglass body. 1" BL, 2 1/2" WH lift, 5.0L NV3550, 31" Tires
hammer189 is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.34128 seconds with 62 queries
